Author Topic: MK3 lower vents  (Read 124625 times)
Offline bored_Welsh_lad
Re: MK3 lower vents
« Reply #300 on: 23 November 2008, 11:13 »
few sets left if anyone fancies any
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline beccasmk3gti
  • golf mk3 gti and a mk3 vr6 182bhp and 223nm
Re: MK3 lower vents
« Reply #301 on: 23 November 2008, 13:06 »
what is the size of the meshed area? just wondering if you could cut the mesh out and fit a cold air feed
Re: MK3 lower vents
« Reply #302 on: 23 November 2008, 13:46 »
you shouldnt need to cut the mesh but heres pics of them with the cold air feed..
Bumper Vents :D
Josho
Re: MK3 lower vents
« Reply #303 on: 23 November 2008, 14:00 »
I see they go on the intake, but do they have a filter in them? How do they fit? I can see the air sensor plugged in.
Thanks.
Re: MK3 lower vents
« Reply #304 on: 23 November 2008, 14:56 »
Dont get what you mean mate?
your buying the bumper vents, you can buy the hosing like eightyeight did and run it up to the airbox as a cold air feed, i now run the air temp sensor into my inlet to have a wee check on the inlet temps.. but some people drill holes in the vents, others mount the sensor behind then vent..
Bumper Vents :D
Josho
Re: MK3 lower vents
« Reply #305 on: 23 November 2008, 16:18 »
Ah, I get it. What sort of filter do you need for that? Like a filter that joins two tubes?
jamie16v
Re: MK3 lower vents
« Reply #306 on: 23 November 2008, 16:41 »
you mean an enclosed type air filter like a pipercross viper or bmc. you dont really need one like that to run the feed to it but it would work better because the cold air is being pulled from outside the engine bay..
Offline Mikester
  • Civic Type R
Re: MK3 lower vents
« Reply #307 on: 23 November 2008, 17:14 »
The vents you buy just fit in the bumper, i have had 2 sets and i dont use a cold air feed or anything. Winter, its cold in that engine bay!
Offline golfwannabe
Re: MK3 lower vents
« Reply #308 on: 23 November 2008, 21:42 »
Pm'd
Offline LazyLunatic
  • MK3 20VT Project
Re: MK3 lower vents
« Reply #309 on: 23 November 2008, 21:48 »
cold air feed pipe just runs to your filter, literally to it. One end can attach to the vent and the other end points at the air intake. You dont need to attach it as such to the filter.
Not sure how effective it is to have a cold air feed?
LL ;)
