Author Topic: MK3 lower vents  (Read 124617 times)
Offline bored_Welsh_lad
Re: MK3 lower vents
« Reply #150 on: 28 March 2008, 06:23 »
thats better remapped  :grin:
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Re: MK3 lower vents
« Reply #151 on: 31 March 2008, 18:33 »
bumpty bump
Bumper Vents :D
Offline GavGti
Re: MK3 lower vents
« Reply #152 on: 31 March 2008, 21:33 »
u still got some of these mate?
Re: MK3 lower vents
« Reply #153 on: 01 April 2008, 06:27 »
iv got an order due anyday now, do you want me to put you down for a set?  :laugh:
Bumper Vents :D
Offline BobbyT
Re: MK3 lower vents
« Reply #154 on: 01 April 2008, 07:32 »
not the best pic, but now painted! look much more oe now  :smiley:
Offline guyn17
Re: MK3 lower vents
« Reply #155 on: 01 April 2008, 12:35 »
Hello chaps, i'm afraid i have a slight problem.....bought these air vents and they're great, can't fault them at all. Problem is with my car though...i removed the old drivers side vent and found a circular metal disc right behind it, its hanging down on a small bracket and has a plug going into the back of it. I'd say its about 3-4inches in diameter.
anybody know what this is as its right in the way of the new vent, I can't even get it in! i'll get some pics up later on. I drive a 96 16v gti if that helps at all. any help would be much appreciated!
Offline golfmk31993
Re: MK3 lower vents
« Reply #156 on: 01 April 2008, 13:11 »
probably the horn
Offline dubsport
  • TDI POWAR!
Re: MK3 lower vents
« Reply #157 on: 01 April 2008, 14:07 »
probably the horn
yeah it'll be the horn, think you can just push it out the way tho  :laugh:
Offline Mikester
  • Civic Type R
Re: MK3 lower vents
« Reply #158 on: 01 April 2008, 14:19 »
i took mine out, you have 2 horns, this bit is the deep sounding bit. Still have a horn, and good air intake  :smiley:
Offline BobbyT
Re: MK3 lower vents
« Reply #159 on: 01 April 2008, 15:12 »
i just bent it out the way!  :grin:
