Author Topic: oil seal valve steams  (Read 1459 times)
Offline oldbanga
« on: 28 March 2004, 12:22 »
Been offered a hell' blue mk2 8v on a 89,with no mot for 100.But oil seal valve steams are buggered.What sort of dollar would it need to put that right??? :o
Offline mk1
Re:oil seal valve steams
« Reply #1 on: 28 March 2004, 18:07 »
You can change the valve stem seals with the head on by using some some ingenuity and made up tools or remove the head and strip it. I have tried both and would recommend the head off as you can give it a clean up and replace the head gasket also. Don't know of the labour cost but it is a good days work and you can price the gasket set from Stuart in the Euro Car Parts forum. Recommend the timing belt and tensioner are changed also.
Steve.
