Author Topic: Engine Revving, Carb problem  (Read 891 times)
Offline Simon86
« on: 26 January 2008, 13:10 »
Hi, first of all. New here (first post) so hello everyone. oh yeah I love MK2's but not much of a mechanic  :undecided:
About a week ago the car starting revving when in neutral like my foot was on the accelerator. Initially I checked the accelerator cable to see if it was getting caught or was twisted. This was not the case, my dad then suggested looking at the automatic choke.
I found that when the car starts on the key, a pushrod comes out to give it a bit of gas, this then pops back in after about 4-5 seconds. My problem is, its not popping back in! The part of the carb that does this is called the 3/4 point unit and I think it is a vacumm thats pulls the rod back in. Anyone know how to sort this problem.
Given you as much info as I can. oh yeah its got the pierburg 2E2 Carburettor.
Anyone experienced any problems like this? Any input is greatly appreciated  :smiley:
Thanks
Offline Simon86
Re: Engine Revving, Carb problem
« Reply #1 on: 26 January 2008, 14:05 »
Ive found a what im looking for. Contacted German and Swedish, they suggested it was the waxstat or pull-down unit. Bit of research and found loads of info.
http://www.honestjohn.co.uk/forum/post/?t=8799&v=f
Anyone with the same problem, this thread should help you out. Ive decided to bodge the job and wedge the push-rod back. NO more high idle speed for me.
Note: Admin, Hope you dont mind me posting a thread to another forum, im sure it can help some other in my situation.
Offline daniel-1986
« Reply #2 on: 26 January 2008, 16:49 »
my mate mite hav the same problem with his 1.6mk2 golf and hes just put clipped a set of mole grips where u can adjust acceletor cable in the engine bay
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 26 January 2008, 20:20 »
The problem is fairly clear -you both need to replace your POSburg with a nice Weber 32/34DTML.
Your Pierturds are over-complex and to the point that they're worn out, which is why they're dicking about.
So, why a Weber?
They're very simple.
They're more efficient than the Pierburg, you're probably going to get 5-10MPG extra.
They deliver a better mix of fuel to the engine - swap out the carb and bingo - more rev-happy, powerful motor.
Just make sure you use the original inlet hoses and the warm-air flap, or you *might* get carb icing from time to time.
Oh, the whole wax-stat thing - you can get replacements from GSF, but I wouldn't bother..... provided you can use a manual choke..... which you can, right?
« Reply #4 on: 28 January 2008, 12:53 »
no need to replace the carb at all, the 3/4 point unit is easy to diagnose and repair.  Check the 2 electrical valves on the back of the carb,m they should both click with the ignition on.  But my money is on a vac line round the back thats come off, have a look at my pierburg 2e2 faq, its in the garages section :)
webber cards are NOT more efficient than a working 2e2, in fact if anyhting they are LESS efficient.  its also a myth that they offer better performace ;)
edit: this has absolutly nothing to do with the waxstat :)
