Author Topic: seatbelt  (Read 756 times)
Offline richard s
seatbelt
« on: 24 January 2008, 21:04 »
my car is due its mot in 3 weeks and my seatbelt has decided to stop retracting i had it apart and made it better for a bit but now it has packed in so i am going to get one from a scrapyard
my car is a 3door so was wondering if one from a 4door would be the same also do any of the other vag cars have the same belts if i cant find a mk2
cheers
Offline Andy!
  • VR6
Re: seatbelt
« Reply #1 on: 24 January 2008, 22:39 »
I guess mk3 ones would be similar,altho much heavier of course and i reckon you should be ok with a four door version dude.
Re: seatbelt
« Reply #2 on: 25 January 2008, 10:36 »
4 door ones are slightly different, the 3 door one have a spring setup to hold the belt down and out of the way of the door for rear passengers.  it should still bolt up though...  A MK3 polo coupe one might work if you can find one?
Offline richard s
Re: seatbelt
« Reply #3 on: 27 January 2008, 20:29 »
so if i can find one that folds down it should fit
Re: seatbelt
« Reply #4 on: 28 January 2008, 08:25 »
pretty much yeah, just check the plug bit on the end will fit your clip thingy.  a 4 door one would still be fine, just that the belt will be in the way of people gettin in the back, but they casn get in de passenger side instead!
