Author Topic: fitting bonnet lifters  (Read 1854 times)
Offline TRANTER
  • golf mkII gti 8v
« on: 24 January 2008, 16:50 »
can any one tell me where to put the ball joints as ive done mine but the bonnet wont shut be a big help with pics cheers there inxx ones
Offline Conker
Re: fitting bonnet lifters
« Reply #1 on: 24 January 2008, 20:02 »
What you've mistakenly bought there is an "air brake".
 :grin:
Offline dabill
« Reply #2 on: 25 January 2008, 11:26 »
ball joint screw replaces the center panel screw for the wing(the 4? screws that are at the top of the wings.
the other ball joint is more tricky.
you need to pop the rubber grommet on the inside of your bonnet, close to where the hinge is on the bonnet, and then drill a small hole through the hinge and into the bonnet. drill the hole between the two bolts holding the hinge to the bonnet.(if that makes sence) but closer to the bolt that is furthest up on the hinge(i.e. closer to the sky..)
you then have the task of fitting the upper ball joint. you have to cram you fingers into the small hole where the rubber grommet was on the inside of your bonnet... whilst holding the small nut that the ball joint screws into ( i litrally glued the nut to the end of my index finger and screwed the ball joint in and the pulled my finger out) once that is done, pop the gas lifter onto the ball joints and do the other side in the same way. them when its all done, open and close the bonnet a fair few times to losen the mechanism a little and bed the lifters in and you should be good.
sorry for poor explanation, while since i did it, and no pics sorry, hope it helps. any more Q's just ask :smiley:
rob
noble tuned - and still not fast enough!
Offline TRANTER
  • golf mkII gti 8v
« Reply #3 on: 25 January 2008, 13:03 »
sound i managed to do it i just used the top hinge hole on both sides and adjusted the bonnet so it sits more forward to the front of the car fitted the struts then the locking clips and it open and closes brill now cheers all just need to put the nut on the back of the two top ones
Offline Ben Lessani
« Reply #4 on: 18 February 2008, 09:40 »
You don't need to drill - as above, it just replaces one of the existing bolts!
