Author Topic: removing old dv problems help!  (Read 1426 times)
Offline MaXXeH
  • Golf MK5 GTI
« on: 23 January 2008, 19:36 »
i got a forge dv that i need to fit befor remap but i cant get the clip of :(
it is a round metal sprung clip that hocks on and a small bit of metal that is pinched, can any one help me please i am pulling my hair out i dont no how to get it of
Offline rossdj1983
Re: removing old dv problems help!
« Reply #1 on: 23 January 2008, 19:37 »
sidecutters?
Offline richw911
« Reply #2 on: 23 January 2008, 19:53 »
Cut it with snips then repace it with a new jublee clip. You might also want to get some silicone pipe for the top hose as im sure it will snap when you remove it  :wink:
Offline ub7rm
« Reply #3 on: 24 January 2008, 07:47 »
I had exactly the same problem when I changed mine and yeah a pair of snips will do the job or if you're careful a dremmel type jobbie will do nicely.  Replace with Jubilee clips as previously said.  I found with mine that the top hose was in good condition and I just pulled the old one off (clip and all) and pushed it onto the new DV without having to remove / replace the clip.  Good job too as I couldn't find a jubilee clip small enough to go into the recess at the top.  A year and a half later and its still going strong.
HTH
2020 BMW 128ti
2017 Golf GTD Estate
Offline MaXXeH
  • Golf MK5 GTI
« Reply #4 on: 24 January 2008, 18:04 »
yea i got it of today both clips where an arse.  i just used a cable tye for the top pipe.
