Author Topic: problem  (Read 1165 times)
Offline xzakx9
problem
« on: 22 January 2008, 21:55 »
i havent got my mk2 on the road yet but everytime i run it for a little while the water boils over......whats the problem with it??
zakx
Offline vw-bob
Re: problem
« Reply #1 on: 22 January 2008, 23:12 »
its getting too hot  :laugh:
sorry couldnt help myself, but i cant be of any assistance
Offline takethefifth
Re: problem
« Reply #2 on: 22 January 2008, 23:47 »
Expansion tank cap knackered?
Offline xzakx9
Re: problem
« Reply #3 on: 23 January 2008, 00:33 »
might be....how could i tell will it be obvious/???
zak
Offline Conker
Re: problem
« Reply #4 on: 23 January 2008, 00:52 »
I think you would be able to see steam coming out of the cap.
Mine overheated for the first time a couple of days ago (albeit on a 150 mile trip) so I've been looking into this issue. The prime suspects are:
1  Expansion cap
2  Low level of coolant in the system
3  Poor ratio of coolant to water - should be circa 50:50
4  Air pockets in the system
5  System thermostat broken
6  Fan switch broken (is your fan coming on?)
7  Fan itself is broken
8  Dreaded headgasket
Perhaps you could tell us more about how it overheats, e.g. all the time, only at idle, is it drinking coolant, whats the oil temp like etc.
« Last Edit: 23 January 2008, 00:54 by Conker »
Offline Goops
  • mk2 gti 16v
Re: problem
« Reply #5 on: 23 January 2008, 12:02 »
As Conker suggested its a process of elimination... follow the list (easiest/cheapest going forward)?
1  Expansion cap
I have to say a flush is probably the most essential thing to do once you buy the motor! Worked a treat for me  :smiley:
Offline rossko
Re: problem
« Reply #6 on: 23 January 2008, 16:44 »
waterpump/thermostat would be my first guess... does the fan kick in?
Offline bobbymk11
Re: problem
« Reply #7 on: 23 January 2008, 20:23 »
had same problem on my 1991 mk2 8v and tunred out needed new waterpump and thermostat...now runs fine...and also put old black expansion cap on..as new blue one was pi**....
Offline Agreeable Slick
  • Unit
Re: problem
« Reply #8 on: 23 January 2008, 20:37 »
change the expansion cap, the seals on the caps are known for deteriorating and letting the water boil over. I think you need one of the blue ones, iirc, do a search of this section and it's mentioned in multiple topics.
