Author Topic: High revs and serious power lag?  (Read 1069 times)
Offline Quadrophenia86
« on: 22 January 2008, 20:31 »
Hi to all.
I'm looking for a bit of advice. My 1.6 Cl has recently started revving very highly when sat idle. Also when driving along there is a serious power lag when in higher gears. I find that i can only get up hills in 2nd and sometimes even 1st gear. The car just doesn't seem to have any pull. After a drive of about 20-30 mins it seems to go back to driving normally but it is really quite irritating. It also over-runs once the ignition is turned off. I had exactly the same problem on my old 1.6 driver and just want to know what the problem is, wether its something i'm doing wrong and how to get it sorted. I would appreciate absolutely any advice or recommendation as its something i really need to get sorted.
Thanks!
Offline cняis
Re: High revs and serious power lag?
« Reply #1 on: 22 January 2008, 20:47 »
could it be an air leak? check for splits in the vacuum pipes around the head/inlet manifold/carb whatever (i dont know the layout on your 1.6, sorry!)
« Reply #2 on: 22 January 2008, 20:51 »
Right. I'll check it out. Thanks a lot!
Offline takethefifth
« Reply #3 on: 22 January 2008, 21:00 »
Check out the Pierberg Carb FAQ in the Maintenance and info section.  Probably the waxstat or something.
« Reply #4 on: 22 January 2008, 21:02 »
I have heard the carb mentioned when it happened to the last one. Worth upgrading to a Weber carb maybe? I've heard its too much trouble.
« Reply #5 on: 22 January 2008, 21:03 »
Not got one myself but apparently a well setup pierberg carb is a lot less maintenance than a webber.
« Reply #6 on: 22 January 2008, 21:05 »
Would i have to get a specialist to set it up or would it be something i could do at home?
« Reply #7 on: 22 January 2008, 21:36 »
Have a read of this http://www.golfgtiforum.co.uk/index.php?topic=33259.0 and see if you fancy a go!
« Reply #8 on: 22 January 2008, 21:58 »
I got lost about halfway into reading that. Maybe i'll go through when i have more patience. Would this be expensive if i got a garage to do it for me? Reading it though has bought up a few more possible symptoms. The temperature gauge does seem to rise very quickly and gets to near max within 20 mins. Then the fan kicks in and it drops. Also the heater has just stopped blowing warm air. This is probably a completely different problem but thought i'd mention it just in case.
« Reply #9 on: 23 January 2008, 10:52 »
Your first post sounds like 2 symptoms, carb icing and lack of coolant flow to the carb, causing the waxstat and autochoke to play up.  Further evidence that this is so comes from the fact after a long drive it goes back to normal :)
To fix that you need to take the inlet manifold off and replace the coolant channel o'ring.
However your last post makes me think something else is the culpret, I'm thinking your waterpump is weak and this is the reason the carb is getting poor flow, the engine is heating up too fast and you've lost your heat!  I'd replace it ASAP, and fit a new thermostat while you're there.
