Author Topic: Removing rear badges  (Read 2224 times)
Offline Dec
« on: 22 January 2008, 18:05 »
Hi guys,
I want to remove the middle VW badge and the GOLF badge on the right. They're held on by holding pins but I cannot see how the come off :undecided: Want to remove them without damaging them as i only want to spray them unless anyone can link me to some new, already black ones? (have tried ebay :undecided: )
Cheers, Dec
Offline Conker
Re: Removing rear badges
« Reply #1 on: 22 January 2008, 19:51 »
If you go in the boot, I think you can see the end of the pins. Pinch them together (mine were funny "split pins")and it should pull off.
Worked on mine anyway.
Offline T_J_G
« Reply #2 on: 22 January 2008, 22:01 »
Just look inside the boot and you should be able to push 'em out. I did this on my old Driver and the badges looked better black. Altough the middle VW badge is a pain in the arse to get it to go back correctly.
Tim
Offline Dec
« Reply #3 on: 23 January 2008, 12:46 »
 :undecided: They dont seem to want to just push out :sad: Ill see if i can get some pics of the bits in the boot tomorrow
Offline daniel-1986
« Reply #4 on: 26 January 2008, 17:17 »
take them out and smooth it off, looks so much better i did it to mine but only smoothed where the VW badge goes
Offline Dec
« Reply #5 on: 26 January 2008, 17:18 »
I dont have the money for anything like that unfortunatly :sad:
Offline daniel-1986
« Reply #6 on: 26 January 2008, 17:22 »
The VW badge shud just pull out quite easily then
Offline monkeyalan
« Reply #7 on: 26 January 2008, 18:00 »
they can be a pain to get out but they do push out. be careful you don't snap a pin on the VW one though.
Offline Conker
« Reply #8 on: 27 January 2008, 15:28 »
A good spray of WD40 as lube helps too, or fairy liquid. Also try warming them up as this helps reduce the brittleness of the plastic.
Offline Dec
« Reply #9 on: 27 January 2008, 16:17 »
sweet cheers mate, going to go and have a go now as its supposed to be the warmest day in a while here!
Basically Lube it up, pull gently, and hope they pop off, gotcha! Cheers guys!
