Author Topic: Mk4 1.6 16V  (Read 2483 times)
Offline transitman
Mk4 1.6 16V
« on: 22 January 2008, 12:50 »
Ok Hope you guys can help, my friend has a Mk4 1.6 16V on a 51plate!
It has the engine management light on and upon scaning it have this fault code come up:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
        P0420 - 35-00 - -
Now is this Catalytic converter related? The car has only done 63000miles
I have monitored the signal on VAGCOM and tried clearing the fault but it comes back after about 100miles
The signal I moinitored was in Block 1 which seemed fine, alot of fluctuation when revving the engine and driving which Im guessing is the probe in the manifold as it looks brand new.
The other signal I monitored was in block 6 i think of VagCom, this value only fluctuated from -2.0% - -3.0%
So from that I would say that there was something wrong there?? I need to find out if its the Cat or the Sensor....
What do I do next??
Thanks chaps.
Offline GTi-Matt
Re: Mk4 1.6 16V
« Reply #1 on: 22 January 2008, 18:48 »
weather its the cat or the sensor u gotta replace them both idealy as the problem will reoccur again and then it just gets pricey, good luck tho
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline richw911
Re: Mk4 1.6 16V
« Reply #2 on: 22 January 2008, 18:55 »
        P0420 - 35-00 - -
What do I do next??
Thanks chaps.
Oxegen sensor  :shocked: Have a look here:
http://wiki.ross-tech.com/index.php/16804/P0420/001056
Offline transitman
Re: Mk4 1.6 16V
« Reply #3 on: 23 January 2008, 04:15 »
Cheers Guys,
Will play with the sensor later today...
How do I perform the aging check on a 1.6 16V? Obviously I have VAGCOM.
Offline transitman
Re: Mk4 1.6 16V
« Reply #4 on: 23 January 2008, 14:45 »
Carried out post cat ageing test and all was fine, what can I gather from this? Is the cat at fault?
