Author Topic: Need advice on a little problem....opinions please!  (Read 1179 times)
Offline Nuttybulldog
« on: 22 January 2008, 09:03 »
I was driving to work this morning as usual, doing nothing different, and all of a sudden i have no windscreen wipers, blowers or rear window heater.
Could this be a fuse or am i going to have to rip my dashboard out tonight?
Nick
I don't remember asking you a god damn thing!
Offline richardhammond
Re: Need advice on a little problem....opinions please!
« Reply #1 on: 22 January 2008, 09:18 »
Sounds like a fuse/s i would have a look at them first. theres a chart of the fuses on the back of the fuse box cover, have a look to see the ones you need to change/inspect. Then go from there!
« Reply #2 on: 22 January 2008, 09:57 »
cheers for the reply  :smiley:
only problem is the fuse box cover is missing. never as easy as it should be is it!!!  :wink:
Offline Conker
« Reply #3 on: 22 January 2008, 12:31 »
I would also check thoroughly that water isn't getting into the fusebox.
Here's the fusebox diagrams:  http://www.golfgtiforum.co.uk/index.php?topic=44637.0
« Reply #4 on: 23 January 2008, 10:59 »
sounds like the #18 x-over relay has come loose, turn on the wipers and wiggle it :)
Offline ToddyGTi
  • I Love GTi's
« Reply #5 on: 23 January 2008, 20:37 »
Had same problem and found it was the X Relief Relay as RJ states. You'll probably find the cause of this issue is water coming in through the bonnet release cable, travelling down it and dripping on the fusebox. You may also want to check your windscreen seal in the area too. I lost my headlights when this happened and due to constant power it blew my ignition switch too. :(
Part of the Booty Club
« Reply #6 on: 24 January 2008, 14:55 »
thank you all
the relay was loose and i do have water dripping into the car so i think it was a mixture of both. im going to move the fuse box a bit and get busy with some silicone at the weekend
thanks again
Offline Peel
  • T4 campervan
« Reply #7 on: 24 January 2008, 15:19 »
Reckon this is why my interior and boot lights are playing up. Will they be OK once car is dried out or  is the damage permanent?
Golf GTI: good enough as it is
« Reply #8 on: 24 January 2008, 15:35 »
depends really, sometimes its ok sometimes the fusebox is full of dirt n corrosion and needs replacing!
