Author Topic: Acceleration probs after changing MAF  (Read 1149 times)
Offline Uj
« on: 20 January 2008, 23:22 »
Car is a 1998 1.8T AGU, Forge 007 DV, revo remap, pipercross foam air filter,50k.
Had intermittant flatspots when accelerating heavily, got a new MAF (exchange from stealer) fitted and this solved the problem for about a week and was working much better than before.
But today I'm getting even worse acceleration problems than i orginally had, first gear is fine, when mildy flooring it in 2nd to 5th gear the rev counter red lines as if i was revving in neutral and the power kicks back in (although not all of it), even worse on the motorway today i could'nt even overtake properly without v. slowly building up speed! Going up inclined roads is a problem also.
Not sure what it can be, haven't checked the hoses, although not sure exactly what and where to check. If these need replacing what ones should I go for? I have noticed lately prior to MAF change a whoosh sound when lifting foot off accelerator, which makes me think its something to do with the DV, but this is spring/piston type not the Bosch OEM diaphram one?!?
Any help on this appreciated.
Thanks.
Offline richw911
Re: Acceleration probs after changing MAF
« Reply #1 on: 20 January 2008, 23:24 »
Maybe a stupid question but what the clutch like? Does it bite high?
« Last Edit: 21 January 2008, 00:10 by richw911 »
Offline Uj
« Reply #2 on: 20 January 2008, 23:27 »
No clutch is fine biting normally, drive was perfect last night, not sure i've damaged a hose or something?
Offline richw911
« Reply #3 on: 20 January 2008, 23:42 »
Hmmm Sounds very much like your clutch to me, You can test it drive along at 30mph in fifth  the try to accelerate away if it revs up you need a new clutch. Might be worth a try  :undecided:
Offline Uj
« Reply #4 on: 21 January 2008, 00:04 »
Thanks richw911. I'll give it a go, but i kinda already know the answer before trying :sad:... hope its not the flywheel as well.
