Author Topic: HOW DO YOU CHANGE A TDI OIL FILTER?  (Read 4961 times)
Offline gti fly bye
  • VW MK4 GT TDI, ITS A SMOKEY ALTERNATIVE!
« on: 20 January 2008, 17:54 »
Never changed one before on a tdi, its a mk4 gt tdi?
Petrol ones make more sense!!! :laugh:
BEAT ANY GTI (TOWING A CARVAN, UPHILL)
Offline saul79
Re: HOW DO YOU CHANGE A TDI OIL FILTER?
« Reply #1 on: 20 January 2008, 18:06 »
lift the engine cover off ,you will see a filter housing filter is in side it ,i use oil filter strap to loosen it.(pd)
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline gti fly bye
« Reply #2 on: 20 January 2008, 21:02 »
so its just a case of twisting off the cap and pulling out the old filter?
Offline Ridg
  • TDI - Soot Happens!
« Reply #3 on: 21 January 2008, 09:58 »
uncrew filter cap,
remove the plastic rod that holds the filter
remove filter
change the 2 o-rings (come with filter)
put filter in
reinsert rod
re-screw cap.
clean up mess
Offline Phil.O
« Reply #4 on: 21 January 2008, 19:17 »
not had a chance to look yet so might be a really simple job but where is the drain for the oil?
gonna change the oil in my gt-tdi but not entirely sure as to how to do it, was easy in my old 306 but not had a go in the golf yet
any hints and tips would be great
cheers all
Phil
a work in progress......someday i might think i'm happy with a car....maybe
so far: 40mm Gmax lowering kit, upper and lower S3 strut braces, pipercross panel filter, Smoothed air box and 18" Audi R8 reps
Offline Ridg
« Reply #5 on: 21 January 2008, 21:54 »
oil change is peice of cake, and you could probably do it without jacking the car up (assuming you can remove the sump cover)
jack up, remove the sump cover (about 8 screws T25 IIRC)
remove sump plug, drain oil, replace with new plug and seal, change filter, add oil run engine on idle job done
Offline Phil.O
« Reply #6 on: 21 January 2008, 22:02 »
i take it the sump plug is obvious?
new plug?
Offline Ridg
« Reply #7 on: 22 January 2008, 09:41 »
new plug?
yeah IIRC its the only bolt on the base of the sump
i've not changed the sump plug myself, as my friends got a machine that drains the oil through the dip stick hole, but i think the plugs come with the seal and you're looking at a few £ so do both.
Offline th3musicmak3r
« Reply #8 on: 03 March 2010, 19:39 »
bit old i knw but what that system that drains it though the dipstick hole surely that cant get all the crap out
Offline Jay
  • balding fat cvnt
« Reply #9 on: 03 March 2010, 21:08 »
There shouldn't be any crap at the bottom, that's what the filter is for  :wink:
