Author Topic: Water Leak  (Read 1370 times)
Offline jharar
Water Leak
« on: 15 January 2008, 21:56 »
Hi people just noticed toady while I was doing something in the boot, The cleaning clothes I had in the boot was all wet then I tried to investigate where this water is coming from , After all that when I use my rear wiper to squirt some water that's when it leaks any Ideas what do I have to check for Cant find the pipe from where the water comes.
Any Ideas?????/
Offline Rhyso
Re: Water Leak
« Reply #1 on: 15 January 2008, 22:02 »
i think it runs up the left rear C pillar as you look at it.
Best bet is to take the boot trim off (2 screws, one in either grab handle, and some clips) and trace it that way.  Its a common fault i'm afraid  :sad:
Offline richw911
Re: Water Leak
« Reply #2 on: 16 January 2008, 17:21 »
Any Ideas?????/
http://www.golfmk4.co.uk/rear_screen_washer_repair.htm
Mk4s you cant beat um  :grin:
Offline saul79
Re: Water Leak
« Reply #3 on: 16 January 2008, 18:36 »
the pipe joins together near the rear top boottrim
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline rheady
Re: Water Leak
« Reply #4 on: 17 January 2008, 20:43 »
Just had a leak from above c-pillar on my golf, leaking onto parcel shelf. I removed trim that goes from c-pillar to c-pillar( very carefully) and was lucky to be able to reach fitting on top left as you look in the boot ( as rhyso said ). Scraped my hands a couple of times but was able to reconnect the fitting and put some insulation tape around it. Don't pull any of the cables or the pipework until you have found both ends of the conector though.
