Author Topic: Mk2 Golf GTi Rebuild!!!!  (Read 1072 times)
Offline Spazzy
« on: 14 January 2008, 18:54 »
Hi Im Aaron and me and my friend are currently rebuilding a non running Golf GTi Mk2.
We are at the momment trying to change the igniton barrell to fit with the new complete set of locks we have fitted so it will all work on 1 key. We have a haynes manual which says we have to prise off the washer (with the spring at the bottom) so we can remove the igniton barrell we have tried everything  :cry: we have tried pulling... leavering with a screwdriver... using some crank clamp pullers to lock onto it and try to pull the washer off but it just wont budge. we spent a hole day trying to remove this washer and i just wont go anywhere. If anyone knows like a trick or nack to remove them, then please could you tell us. we cant take it nemore we have tried everything we could possibly try we even resorted to a hammer >.<... if you could get back with a answer it would be greatly appreciated  :smiley:
Aaron
Offline hainesz
  • MK4 GTi 1.8T 20v AGU
Re: Mk2 Golf GTi Rebuild!!!!
« Reply #1 on: 14 January 2008, 20:49 »
Lol... i have been in many situations like yours fella and i know how stressfull it can become... i tend to get the angle grinder out once all fails... im new to vw's myself so i cant really help you mate, but there is some helpfull people here that could possibly help... good luck my friend
...Burn Rubber...Not Your Clutch...
Dinky
« Reply #2 on: 14 January 2008, 21:49 »
Try posting in the garage/mk2 section if you haven't already darl
Dinx :kiss:
Offline Neaty
« Reply #3 on: 14 January 2008, 21:57 »
hello and welcome  :smiley:
Offline monzablue16v
« Reply #4 on: 14 January 2008, 22:07 »
I seem to remember when I did mine I had to drill a certain part with a certain sized drill bit and then release a spring inside it. With the key in the ignition but not turned or with it turned can't rightly remember :) It was in the Haynes book of lies, fabrications and half truths!
