Author Topic: On going issue  (Read 1639 times)
Offline barrett84
On going issue
« on: 14 January 2008, 10:44 »
Hello all still having issue with the revs going up but no extra speed, some one was saying about the n75 valve and a membraine that is attached to it? also about a n275 valve, can any one tell me what these do could it relate to this issue? also where about are they located and are they easy to chenge cheers guy's.
Offline Ashmond
  • Money, b!tches And Boost
Re: On going issue
« Reply #1 on: 14 January 2008, 11:30 »
I think this is the problem with me too, what top speed can you get up to?
Unplug your MAF sensor, if you can rev more freely then you know it needs replacing!
Offline barrett84
Re: On going issue
« Reply #2 on: 14 January 2008, 11:39 »
yeah i thought this and changed my MAF censor but no difference.
Offline barrett84
Re: On going issue
« Reply #3 on: 14 January 2008, 14:01 »
I am thinking of getting the N75 j valve has any one any opinion if this valve is the best to get?
Offline Conker
Re: On going issue
« Reply #4 on: 14 January 2008, 17:08 »
Presumably you've ruled out the clutch?
Offline Turbo_Dazza
Re: On going issue
« Reply #5 on: 15 January 2008, 20:32 »
Sounds a bit more like to me as well, my mine went you had to give it extra revs just too get it
going, my mate did a test for me cause i didnt know at the time put it into 3rd gear and try and set of but
only lifting the clutch pedal slowly and if you can get it right near the top without stalling it you clutch is fooked will probably need a new fly wheel as well,
Daz...
www.ds-image.co.uk
build thread coming soon!!
