Author Topic: Throttle body clean.  (Read 8592 times)
Offline richw911
Re: Throttle body clean.
« Reply #20 on: 23 January 2008, 18:38 »
Thanks for the post on the throttle body clean
Cleaned my TB today on 1.8t agu engine. All went well, it was filthy! I don't have access to vag com so I just took it for a drive bout 30 miles hoping to reset however it now idles @ 1400 rpm... sometimes up as far as 1600. Has anyone else had this problem? Theres a major improvement in the smoothness of the drive now just the idle problem still remains :undecided:.
Any suggestions?
Mines an AGU. Have had no probs with it since. The engine will idle higher when cold (im sure you know this  :evil:) does it do it all the time?
Offline thehectorman
« Reply #21 on: 23 January 2008, 19:08 »
Yea it does it all the time. The reason I cleaned it in the first place was to see if it would stop idling at 1200rpm now its worse :huh: Do ya think it could be the MAF? I may go to a garage n get it plugged into a comp n see if any faults pop up..
Offline richw911
« Reply #22 on: 23 January 2008, 19:31 »
Ah it was doing it before i see. Yeah i would get a fault code reader on her and see what comes up TBH
Offline MaXXeH
  • Golf MK5 GTI
« Reply #23 on: 23 January 2008, 19:33 »
yea mine is the same after i cleaned it  :undecided: dont get it and i vag com'ed it???
« Reply #24 on: 23 January 2008, 19:37 »
Yea I'll get it done asap cheers 4 d help richw911  :smiley:
Offline richw911
« Reply #25 on: 23 January 2008, 19:45 »
No probs. Ive just got a fault code reader cost £35 very handy peice of kit saves paying bloody garages! (Wanted vag com really but cant afford a laptop at the mo  :rolleyes:)
« Reply #26 on: 23 January 2008, 19:57 »
Oh where did u get the fault code reader? That wud b handy lil bit of kit to have (Ideally I want vag com) but that wud do for d mo..
Offline richw911
« Reply #27 on: 23 January 2008, 19:58 »
The bay where else  :grin:
http://cgi.ebay.co.uk/VW-GOLF-FAULT-CODE-READER-SCAN-ENGINE-ABS-SRS-AUTOTRANS_W0QQitemZ160200749086QQihZ006QQcategoryZ30921QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Offline MaXXeH
  • Golf MK5 GTI
« Reply #28 on: 23 January 2008, 20:13 »
like i said i have vag com and after clean mine is the same as urs 1400/1600 idle
Offline richw911
« Reply #29 on: 23 January 2008, 20:17 »
I think he want to check for fault codes for a dodgey maf sensor  :smiley:
