Author Topic: Throttle body clean.  (Read 8593 times)
Offline richw911
Re: Throttle body clean.
« Reply #10 on: 13 January 2008, 18:54 »
They say you need to re-allign the throttle body with vag com after youve taken it off for a clean
If you read the link i put up it says you CAN re allign it using vag-com if you have it, BUT YOU DONT HAVE TO.
Because the ecu will reset itself after 20 miles, Ive spoken to three other people who have also done this without the need for vag com.  :smiley:
Offline J5H VW
« Reply #11 on: 14 January 2008, 11:22 »
Great post - and I want to do this very soon.  Aiming for this weekend!
Have read the link to the other forum that shows details of how to do this task too and there is some debate over whether you should be able to move the butterfly on a DBW engine, since it is controlled using a stepped motor.
Some say its ok to "force" it in effect, others say to get someone to sit in the car, with ignition on (but engine off) and to press the throttle so that it opens the butterfly so it can be cleaned.
What do you guys think, and I want to do this, but dont want to screw up the throttle body!  I have a DBW engine, AUM.
2001 VW 1.8t Golf GTi 5 Door (AUM). Xenons, Heated Black Recaro Leather, Front Arm Rest, Stubby Alloy Bee-sting, Climatronic, Heated Washers, Headlamp Jets, Touareg Torch...and a fire extinguisher should it all go wrong! - NOW SOLD
2005 BMW 330cd M Sport Convertible - Sparlking Graphite, Full Electric and Heated Red Leathers, TV, Nav, Bluetooth, Active Xenons, Wind Diffuser
Offline J5H VW
« Reply #12 on: 15 January 2008, 16:02 »
BUMPing this post.
Anyone got any advice on my post above, regarding cleaning throttle bodies on DBW cars?  :undecided:
Hoping to do this task this weekend, so any advice would be much appreciated.
Sorry to BUMP it - not trying to resurrect the dead!  :evil:
Offline richw911
« Reply #13 on: 15 January 2008, 17:57 »
I would get some one to sit in the car and put there foot on the throttle tbh mate. Why force it if you dont have to? Defo worth doing this my car drives soooo much better now  :smiley:
Offline ashw831
« Reply #14 on: 19 January 2008, 15:01 »
any 1 know how to clean throttle bodies on the 1.8 20v n/a plz needs doin!! cheers
Offline Ashmond
  • Money, b!tches And Boost
« Reply #15 on: 19 January 2008, 17:31 »
I did this on my car today and also sorted the boost problem out (turned out to be the chip the tuner put in my ecu)
Offline MaXXeH
  • Golf MK5 GTI
« Reply #16 on: 20 January 2008, 15:51 »
lo lads! i done this on my car today but i dont no if this is normal,  When i drive a 2k/3k and take my foot of the throttle it seems to hold the revs and drop very slowly is that normal?
my throttle was black!  just want to make sure this is correct or i may have to take it back of again :P
Offline richw911
« Reply #17 on: 20 January 2008, 16:39 »
Normal  :wink:
Offline MaXXeH
  • Golf MK5 GTI
« Reply #18 on: 20 January 2008, 17:23 »
good for me never did that befor :P  made how much a clean makes :P
Offline thehectorman
« Reply #19 on: 23 January 2008, 13:35 »
Thanks for the post on the throttle body clean
Cleaned my TB today on 1.8t agu engine. All went well, it was filthy! I don't have access to vag com so I just took it for a drive bout 30 miles hoping to reset however it now idles @ 1400 rpm... sometimes up as far as 1600. Has anyone else had this problem? Theres a major improvement in the smoothness of the drive now just the idle problem still remains :undecided:.
Any suggestions?
