Golf mk4
Wazzzer
oil????
Topic: oil???? (Read 1566 times)
kyle_GTi
GTI forum regular
oil????
13 January 2008, 13:56 »
i put 5-40 in mine but its drinking it so do you rekon if i put a thicker oil in it will stay there not burn away am affraid al seez my engine coz this is the second time av checked the oil and its bin below the min mark
saul79
Re: oil????
13 January 2008, 14:07 »
putting thicker oil is not going to stop it from burning it mate, you need the engine inspecting ,could be valve guides,stem oil seals ,rings etc.what engine is in it
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
kyle_GTi
GTI forum regular
Re: oil????
13 January 2008, 14:11 »
1.8 20v non turbo its ment 2 be a comon to burn that much oil but its costing to much at £20 at a time
saul79
Re: oil????
13 January 2008, 14:20 »
whats the mileage on it ,if its high then it will use a lot of oil ,you got any oil leaks from any where ,like the rocker cover ,front and rear main oil seals are both common.if its defo burning it you need to be thinking engine rebuild or replacement 2nd hand engine
kyle_GTi
GTI forum regular
Re: oil????
13 January 2008, 14:24 »
it dusnt burn that much just that 2month ago i put fresh oil in and its low now its only just under 90 thou on a s plate,i had it on the ramps and check for leaks and the sump nuts were a bit loose so i just torked them up
AlanD
Serious forum addict
MK5 2.0T 16v
Re: oil????
14 January 2008, 20:46 »
2.0 or 1.8T ?
Kinetic Tuning - South Wales
Tuning Werkes - South London
R-Tech - Leicestershire
Carbon Chip Tuning - Manchester
kyle_GTi
GTI forum regular
Re: oil????
Reply #6 on:
15 January 2008, 12:41 »
its 1.8 20v non turbo i have put the wron oil in i should of put 15-30 in and the 5-40 is way to thin
Ivor Mk4 Turbo
Forum addict
2014 PP GTi Manual
Re: oil????
Reply #7 on:
15 January 2008, 12:53 »
According to the Duckhams booklet, you want either 10W-40 or 15W-40. (Same as the Turbo).
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'!
227
bhp, KO3-S'd AGU,
R-TECH Spec 2 map
, Forge 007P,
Blueflame Turbo-back
, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines,
TT Short-shifter
, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>>
http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Golf mk4
Wazzzer
oil????
