Golf mk4
Wazzzer
Mandrel Bends Boost Pipes.......
Topic: Mandrel Bends Boost Pipes....... (Read 1520 times)
silveradobullet
'Mr. Green, You Are in Danger..... Take the Stairs
13 January 2008, 10:54 »
.... hey guys, in the process of customising my pipework and replacing bits and bobs on the 1.8T!!
anybody know the exact diameter of the metal boost pipe that sits at the rear of the engine(where DV flange is)?
saul79
Re: Mandrel Bends Boost Pipes.......
13 January 2008, 11:03 »
i,m sure its 2"
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
silveradobullet
13 January 2008, 11:08 »
seems a bit small...... that means itll be only 50mm diameter..... mmmm you possibly could be correct actually, coz alot of aftermarket boost pipes are about 60mm.....
saul79
13 January 2008, 11:13 »
is yours agu,
saul79
13 January 2008, 11:15 »
there 2 1/4 " just measured mine
silveradobullet
13 January 2008, 11:49 »
yeh between 58mm-60mm sounds about right! cheers dude!
shall i measure mine just 2 make sure?
saul79
Reply #6 on:
13 January 2008, 12:22 »
i would
silveradobullet
Reply #7 on:
13 January 2008, 12:44 »
yeh i got 58mm too! but ive got a problem now....... if i make the pipe out of stainless, ive got 2 weld the 2 flanges on it for the DV and intake..... uh oh! so possibly may need 2 rethink strategy!!!!
Golf mk4
Wazzzer
