Author Topic: help please on brakes  (Read 659 times)
Offline mattyswift
« on: 12 January 2008, 22:07 »
i have changed the brake fluid on my 8v gti and i used the easy bleed and closed the comp valve. the problem is the pedal needs pumping to get a good brake and when i let it off it goes back to being worse. do you think its still air in the system as i kept bleeding it and it got abit better. someone said it might be the master clylnder but the brake is working great once pumped.
help please
Offline saul79
Re: help please on brakes
« Reply #1 on: 13 January 2008, 10:38 »
doesnt the comp valve need to be open :smiley:
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline Diamond Hell
  • Opinions я Us
« Reply #2 on: 13 January 2008, 10:54 »
Get the compensator valve open and then you might need to spend another few minutes with a hose on the bleed nipple and an accomplice pumping the pedal, rather than using the Ezibleed.
I was amazed at the amount of air that came out and the amount of pumping and Ezibleeding it took to get the air out when I replaced a compensator valve recently.
