Golf mk2
Engine flooding problem
Topic: Engine flooding problem (Read 790 times)
smithysmoo
12 January 2008, 13:31 »
This has happened a few times and its a trifle annoying, any ways round it.
8v PB engine. Usually starts on the key but very occaisionally it will cut straight out and then I have a hell of a job restarting. The engine wil turn for a log time without firing and if it does fire it will cut straight back out. Have managed to get it started eventually but after a good ammount of trying. I can turn the car off and on when its eventually running not a problem.....
Any ideas so I don't get stuck somewhere.
smithysmoo
Re: Engine flooding problem
13 January 2008, 16:29 »
nobody
BaxGTI
GTI forum regular
13 January 2008, 16:35 »
May be damp on your HT leads or dizzy cap. Take all the leads out and spray everything with WD40 and then try it.
Mk2 8v GTI Budget Project
http://www.golfgtiforum.co.uk/index.php?topic=73778.0
Diamond Hell
Serious forum addict
Opinions я Us
13 January 2008, 16:54 »
Or the temperature sender that controls the cold start might be failing.
Have you replaced the cap, rotor arm, leads, plugs and given it a good service in the past year?
smithysmoo
13 January 2008, 17:22 »
Was serviced just before I had bear in ming this only happens occasionaly but then is a real pig. Wheres this cold start temp sender.....
Dragon6
Here all the time
13 January 2008, 17:58 »
The sensor is the blue two pin connector front of cylinder head facing you as you look at engine,on the black plastic water flange..
Golf mk2
