Author Topic: Which one?  (Read 3375 times)
Offline OutlawStar
Re: Which one?
« Reply #10 on: 12 January 2008, 01:09 »
sweet cheers for the guidance ive just ordered the 007p, sounds like it should fit the bill!
Just a thought mate, You might want to get some silicone pipe for the top vacuum hose on the dv.
When you come to remove the old one you will find that the old rubber pipe has become brittle from years of being heated and cooled under the bonnet and it will snap.  :wink:
good shout didnt think of that, any recomendations im on a bit of a budget so nothing to pricey, but need it to do the job!
Offline richw911
Re: Which one?
« Reply #11 on: 12 January 2008, 06:07 »
Any silicone pipe will do mate (as long as it is the correct size!) Most good motor shops will be able to help you. Got mine from forge IIRC it was about £8 inc post for 3m.   :wink:
Offline OutlawStar
Re: Which one?
« Reply #12 on: 12 January 2008, 14:10 »
what dimensions are the silicone hoses that link up to the dv? i cant measure them as i dont have my car at the moment!
Offline leeroy20vt
  • h reg mk2 gti
Re: Which one?
« Reply #13 on: 12 January 2008, 17:30 »
i was told it is 4mm internal dont qoute me on this tho sure some 1 will confirm
Offline richw911
Re: Which one?
« Reply #14 on: 12 January 2008, 22:41 »
Your right mate its 4mm bore. check out the " VC04" this is what i have on my dv:
http://www.siliconhoses.com/content.asp?inc=product&catalog=0022VC&cat=0022VC
 :wink:
