Author Topic: Wiring Loom help needed please!!  (Read 2310 times)
Re: Wiring Loom help needed please!!
« Reply #10 on: 16 February 2008, 18:21 »
no the driver only has the wiring for the level sender.  the loom runs along the inner sill then out to the boot area :)
You can pull out all your old pump loom, only issue is you'll need to find some CE2 pins to fit into the pump plug, have a look at my fusebox faq and it'll show you where.
Offline mattp1983
  • Keep it VAG :)
« Reply #11 on: 16 February 2008, 18:28 »
Cheers mate, have all your guide printed out, was a godsend labelling up the VR engine and clock looms ready for connection.
So looking at your guide the fuel pump plugs into position M with it sharing a plug with the fuel level sender and sunroof map reading light apparently..... Presumably my Driver loom will have two out of these 4 positions used in the multi plug so if I get a VAG wire repair kit then  simply plug my existing wires into the correct positions on that plug?
1989 Golf GTI 8v Tornado Red <br />2004 Bora Highline TDI 180bhp Shadow Blue
« Reply #12 on: 16 February 2008, 18:29 »
yep thats right, though personally I'd chop a few plugs out of a MK3 in the scrappy and use that insted  :grin:
VeeDubGTI16v
« Reply #13 on: 16 February 2008, 21:45 »
rubjonny, do you have the details about how to splice the idle controller into the interior loom? im putting a 16v into a 85 kjet 8v by the way if it makes a difference.
« Reply #14 on: 17 February 2008, 00:00 »
i gots diagrams, pm me your email address :)
