Author Topic: the 2lt build will go ahead lol  (Read 1959 times)
Offline golf mk2 tornado red
  • same s**t just another day
« on: 07 January 2008, 20:19 »
i think ive found a 2lt bottom end for my rebuild   its a ABK with dizzy and bits n bobs .says its 45degree block would this be fine for my pb head
  thanks guys n girlies
Re: the 2lt build will go ahead lol
« Reply #1 on: 07 January 2008, 21:34 »
a pic ov the engine
just over 10k
will it be ok for the build
  the build must go on   lol
Offline ben44
« Reply #2 on: 07 January 2008, 21:43 »
hey i saw that on ebay aswell!lol i should think it will be ok as long as you use a mk2 golf sump and oil pick up pipe!
My signiture sucks..........................
« Reply #3 on: 07 January 2008, 22:08 »
yeah thats the 1 why the sump and pick up .not to clued up on this conversion cheers mark
Offline dubslug
« Reply #4 on: 08 January 2008, 17:32 »
you will still need the 2e dizzy not ABKs
1992 pearl grey 8v
Offline ben44
« Reply #5 on: 08 January 2008, 18:39 »
well if the engine comes out of a car thats mounted longditudinaly, the sump and pickup is differant as it sits at a differant angle.
« Reply #6 on: 08 January 2008, 18:56 »
ov course
the dizzy i now about  cheers guys
dubslug_ do u have a big valve head .wot gains will i get from this.  been to c my mate tonite hes s**t hot with engines
hes guna use my other head and open it up also my manifolds port n polish the lot. hes a great friend (painted my red golf for nothing) ov course i saw him right
he was asking if its worth big valving the head. dont wana spend a fortune doin this for little hp gains
just reconning my other box get my other head done new 2lt block will be already to put in when done.
also putting in a cam (fast road) is this a good option and a chip.
if i missed anything i should know any mods etc will be very welcome
 thanks guys .you all feel like brothers :wink:
Offline fused
« Reply #7 on: 08 January 2008, 19:31 »
I had my short block balanced; crank, fly and con-rods. Made a lot of difference, rev's smoothly and idles lovely and if you are putting in a fast cam the power band will probably be higher so you will be spending more time at higher RPM's! a worth while upgrade for these older engines!
« Reply #8 on: 08 January 2008, 19:42 »
so a good option then cam wise cheers
how much did it cost you to get it balanced a rough price is expected as with different specialists ect
« Reply #9 on: 08 January 2008, 20:09 »
wooh won the block. £90 with 10k wear  sorted it will soon all come together.
