Author Topic: TDI With Anniversary Alloys - What PSI & Fuel consumption..  (Read 3845 times)
Offline knobby
Hi Guys
Have recently fitted 18" Anniversary alloys to my Golf TDI. I am currently running at 30PSI all round, is this correct or can anyone recommend a PSI?
Also since i have fitted the alloys the MPG seems to have dropped, is this me just imagining things or could the alloys effect this?
Any advice welcome, cheers in advance guys!
Knobby...
Old VW's never die...they just go faster!
Offline Rhyso
Re: TDI With Anniversary Alloys - What PSI & Fuel consumption..
« Reply #1 on: 06 January 2008, 21:34 »
with my 16's i run 34 front and 32 rear so i'd up the PSI a little bit mate
and yeah fitting bigger alloys will affect the MPG  :laugh: especially with your tyres under-inflated
saw your post a few days ago about your TDI but which model did you buy?? 115, 130 or 150?
« Last Edit: 06 January 2008, 21:42 by Rhyso »
Offline knobby
« Reply #2 on: 06 January 2008, 22:02 »
Its a 115... Hoping to chip is asap..
When i first got the car i could get it to do about 48-50 MPG.. Now im stuggling to do 46 at 70MPG.. i really didnt think the wheels would make a difference. I thought the larger the wheel the less work the engine has to do to cover a greater distance. the smaller the wheel means more work and higher revs... NO?
Knobby
Offline Phil.O
« Reply #3 on: 06 January 2008, 23:14 »
from what i know when you put bigger rims on you then use lower profile tires so the wheel is actually about the same diameter but wider like 225 or whatever you've gone with so it actually takes more effort from the engine to turn the wheels, having them at the right pressure will help but wider tires will make more work for the engine so mpg will go down a little
plenty worth it for the nice rims though  :grin:
a work in progress......someday i might think i'm happy with a car....maybe
so far: 40mm Gmax lowering kit, upper and lower S3 strut braces, pipercross panel filter, Smoothed air box and 18" Audi R8 reps
Offline spydoor
  • -[ MkIV GTTDI PD150 - Revo Remap ]-
« Reply #4 on: 15 January 2008, 18:56 »
Check out this handy little tool for making sure your new overall wheel and tyre size is the same as orig.
http://www.miata.net/garage/tirecalc.html
This way, as Phil.O says, the overall wheel size hasn't changed.  But, I would imagine, the tyres being wider will have a negative effect on MPG.
P.S. Where the hell did you manage to find a set of anni wheels?  Been looking for a set for ages  :sad:
« Last Edit: 15 January 2008, 19:00 by spydoor »
Offline copland_71
  • Its not the fuel..... Its how you use it!
« Reply #5 on: 10 February 2008, 10:47 »
Thats the same wheels I'm running and I use 34 on the front and 33 on the back.
Spark plugs not included.
Offline copland_71
« Reply #6 on: 10 February 2008, 10:48 »
Spydoor mine came with the car but if you look on ebay or pistonheads.co.uk you may find a set.
Offline knobby
« Reply #7 on: 11 February 2008, 20:43 »
Hey...
I am getting about 43-44 to the gallon at the mo.. which is about 460-470 to the tank and i am running 18" BBS Anniversary alloys..
Let me know what others are getting please.
Knobby..
Offline Ridg
  • TDI - Soot Happens!
« Reply #8 on: 11 February 2008, 21:37 »
i get at least 500 from a tank, normally get between 520-550 running on the standard 16" 's any mainly on cruise control.
Offline knobby
« Reply #9 on: 13 February 2008, 12:41 »
Thinking about selling my Anniversary wheels if anyone is interested.
http://www.golfgtiforum.co.uk/index.php?topic=76824.0
