Author Topic: are my wheels too wide  (Read 1137 times)
Offline juleshs
« on: 06 January 2008, 14:32 »
i have got 15" wheels with 205/60/15 tyres standard suspension
if i hit a bump or throw it into a corner hard, the tyres rub on the arches (badly)
i dont know the dimension of the wheels there are plenty of numbers on them but i dont know what they mean. can anyone advis me on this problem?
Offline adihodgson
  • DUB......Deuchland's ultimate benchmark
Re: are my wheels too wide
« Reply #1 on: 06 January 2008, 14:35 »
hi,
on 15" rims you should ideally be using 195/50/15.......then slam it :grin:
Offline Mew
« Reply #2 on: 06 January 2008, 14:37 »
The tyres have quite a high profile which certainly won't be helping things. 195/50/15 or 195/45/15 are about right for a 6-7x15" wheel on a mk2.
As for the size and offset of the wheels, it should look something like "6j" "7j" etc (6" wide and 7" wide) and the offset normally looks like "et33" "et25" etc.
 :smiley:
Offline juleshs
« Reply #3 on: 06 January 2008, 14:43 »
it says on the wheels 7j   off24 is this ok
Offline Mew
« Reply #4 on: 06 January 2008, 14:46 »
Is your car lowered at all? Those wheels with anything up to roughly a 40mm drop and 195/50/15 tyres should be fine, but the tractor tyres at the mo will be causing the issues, not the wheels.
Offline juleshs
« Reply #5 on: 06 January 2008, 14:53 »
car is not lowered at the mo but soon will be. thanks for advise
Offline Mew
« Reply #6 on: 06 January 2008, 14:54 »
Go on then, lets see the offending items  :wink:
Offline Organisys
  • Old and Slow...
« Reply #7 on: 06 January 2008, 15:17 »
Fit 195/45/15 or 195/50/15 Toyo Proxes or Goodyear Eagle F1, then lower it.
Offline kittie
« Reply #8 on: 07 January 2008, 11:40 »
I have the same size/offset wheels with 195/50/15 tyres on. They scrub quite a bit! However, am in the process of having new suspension fitted (-35mm to 40mm) as I suspect the scrubbing was due to knackered shocks.
If this solves the problem I will let you know!
