Author Topic: Help with My Polybushed Wishbones  (Read 2743 times)
Offline Golf8vGti
« on: 05 January 2008, 21:08 »
Hi all
Need some help now i dont know if its me being stupid but i bought some Mk2 Wishbones with the powerflex bushes already fitted, what i want to know is are the wishbones sided?
Also if i lay them down as they would be on the car as shown in the picture then it appears that i end up with one of the rear bushes being upside down. Is this correct? I have been told by the supplier that this is normal on a mk2 for one wishbone to be upside down.
Offline Simpson
  • one day il learn
Re: Help with My Polybushed Wishbones
« Reply #1 on: 05 January 2008, 21:11 »
no mate it doesnt matter which side you use, just remember to lower the subframe slightly to slide them in, you dont have to completely remove the subframe mounting bolt.  :smiley: as for the wishbone not entirely sure but i cant imagine it would make any difference as they are symmetrical on both sides.
i must buy a new car!
Offline Golf8vGti
« Reply #2 on: 05 January 2008, 21:20 »
mmmm i see what you mean, i just get the feeling that there wrong personally dont look right to me and would rather have a bit more advice before i start ripping my car apart.
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #3 on: 05 January 2008, 21:42 »
Where did you get them from with the bushes already fitted if you don't mind me asking  :smiley:
Offline Golf8vGti
« Reply #4 on: 05 January 2008, 22:06 »
Ebay is your friend, but if you read the rest of my post you'll notice that im unsure as to them being correct  :sad:
Offline SimonGTI8v
« Reply #5 on: 05 January 2008, 22:42 »
Hi mate, mk2 wishbones aren't sided, as Simpson said. If you're not sure though try having a look on the GSF or VWSpares websites for a comparison
Si
Offline Golf8vGti
« Reply #6 on: 05 January 2008, 22:45 »
Yep did that checked GSF and there is only one listing for Mk2 wishbones, this is why im so confused cause when i look at them as they would be on the car i end up with one being upside down.
Offline Mew
« Reply #7 on: 06 January 2008, 00:28 »
uh-ho, one of us has been done over!  :undecided:
On the smaller side of the bush it says "Metal washer against radiused side", not too sure what washer and radiused side it is referring to though.
Offline jammac
« Reply #8 on: 06 January 2008, 11:20 »
how are the original wishbones set up on the car? the same way round or opposites?
ITS A TRAP!
Offline Golf8vGti
« Reply #9 on: 06 January 2008, 11:56 »
MEW : From what i can see yours look correct there laying as they would on the car and you have both of the larger bushes on the same side, if i lay mine like that i end up with one having a larger bush and the other being a smaller one . Also where did you get yours?
JAMMAC: And from what i can tell on the car both sides are the same way up
