Author Topic: alternator  (Read 1001 times)
Offline juleshs
alternator
« on: 05 January 2008, 18:41 »
do any of you guys know if a mk2 alternator v belt pulley will fit on a mk3 alt" that as got the groved belt pulley on
Re: alternator
« Reply #1 on: 09 January 2008, 13:19 »
nope, mounting points are also totally different as will the offset most likely.  why do you ask? ;)
Offline juleshs
Re: alternator
« Reply #2 on: 10 January 2008, 12:29 »
need rid of the serpentine setup because pulleys on end of crank a touching chassis
Re: alternator
« Reply #3 on: 10 January 2008, 12:35 »
right, if you want a MK2 belt you'll have to remove the crank & waterpump pulleys, swap on MK2 items and unbolt all the alternator & pas brackets then fit mk2 stuff.
