Author Topic: HELP  (Read 774 times)
Offline golf mk2 tornado red
  • same s**t just another day
HELP
« on: 05 January 2008, 17:33 »
right bypassed my heater valve put a new thermo in even put my golfgti.co.uk stickers in and she still wants to play mind games with me
problem ignition on lights off fine
lights on tonite however no dash lights no rev counter no fuel gauge just the water light flashes now and then along with oil light also full beam light on
move my scroller to dim dash lights oil light stays on move to brighten goes out main beam lights on again .
oh i steam cleaned my gearbox and front ov my block my ov got abit in the alternator (belts fine) adjusted it this morning
problem unsolved  :sad:
 oh and fixed my leaky sunroof  FINGERS CROSSED
Re: HELP
« Reply #1 on: 06 January 2008, 13:22 »
guys i need ya help
Offline Conker
Re: HELP
« Reply #2 on: 06 January 2008, 15:08 »
A few simple suggestions seen as though no-one has posted yet...
1)  Have you checked all the earth points?
2)  If you've been steam cleaning stuff, perhaps you've soaked something important. Maybe a good long drive would dry it out?
3)  Pull all fuses and relays and clean/check them.
Re: HELP
« Reply #3 on: 06 January 2008, 15:19 »
every thing is dry so not that
will check the others tom at work
1 good has come from this my display on my clocks went all crystilized and now it works again
  thanks for advice  guna changa my light switch summat mite be shorting inside it
Re: HELP
« Reply #4 on: 07 January 2008, 18:55 »
fixed the barsteward today great
broke the earth to the rocker box while doin the heater
the one thats in the loom on the blue temp sender wire
woop woop :smiley: :smiley: :smiley:
