Author Topic: judder or misfire when accelerating  (Read 3145 times)
Offline dragongreen16v
« on: 23 March 2004, 19:27 »
I've read through the forum and this doesn't seem to be a common problem, so if anyone can help....   I've just bought a Mk3 (98) 16 valver, it's just developed a bad judder when I accelerate, as if it's struggling for fuel. I took it to a garage and they've said it isn't the fuel pump or relay and said I should take it to a VW garage to be hooked up to a diagnostic computer. I'm booked in later this week but in the meen time if anyone has encountered this problem drop us a line. I'll let u know if they find a problem.
golfvr6
Re:judder or misfire when accelerating
« Reply #1 on: 23 March 2004, 19:40 »
Try changing the fuel pump and ecu relays, seems to solve everyone else's car with the same problem.
Offline paladin
  • Call me old and I'll smack the sh!t out of you.
« Reply #2 on: 23 March 2004, 19:50 »
'Juddering' doesn't sound like a fuel problem.. (wait.. OK..no)
Check your wires for arcing...  If they're touching each other or anything metal they'll eventually arc.  And that would give you a 'judder'. - most common.
The coil is also a player in the 'judder' arena, but I doubt it.
Also, what year, how many miles?
« Last Edit: 23 March 2004, 19:53 by paladin »
'94 Mk III 2.0
Bosal cat-back:K&N w/mod.airbox:GIAC
Alpine 9815
JBL BassPro
CDT Audio HD-52 in reinforced q-form kicks
MB Quart 218.21 (mid's) in rear
QuietCar (being applied)
golfvr6
« Reply #3 on: 23 March 2004, 19:53 »
Juddering usually means fuel problem.
If it is electric ie. ht leads then you will get misfiring or cutting out all together.
« Reply #4 on: 23 March 2004, 20:01 »
only 40k. one thing I didn't mention, it's idling pretty eratically.
Offline Gedi
  • u shouldn't have a car if you can't take a joke!
« Reply #5 on: 23 March 2004, 21:13 »
sounds like the timing and the leads...........
Offline paladin
« Reply #6 on: 24 March 2004, 00:08 »
I would think if it were a fuel problem then you'd have loss of power and stalling problems..
'94 Mk III 2.0
Alpine 9815
JBL BassPro
Offline Overseer
« Reply #7 on: 24 March 2004, 10:10 »
run it on optimax too :)
