Golf mk2
Can't select 5th gear, 8v gti
Topic: Can't select 5th gear, 8v gti (Read 2782 times)
martinb
Forum Supporter
04 January 2008, 15:55 »
Just a quick query for a workmate, his f-plate mk2 8v gti will not go into 5th gear and he is worried it may be gearbox/clutch. Are there any other common faults that could cause this? I seem to remember seeing somewhere that there could be another common, less serious fault that can cause this.....
Martin
dubsport
TDI POWAR!
Re: Can't select 5th gear, 8v gti
04 January 2008, 15:58 »
has one of the pins come out of the gear shift rod?
hapened to me a few days ago ... but i could only find 1st
Horney
10k hero
Racing, Trackdays, Starwars.
04 January 2008, 16:11 »
check the two little shift rods in the engine bay, if one of these is cracked or broken this is often the result.
Nick
JimR
GTI forum regular
04 January 2008, 16:16 »
On mine i have to press the lever down, as you do going into reverse, to select 5th. I think its the relay shaft ball/bush and the gear linkage bushes that are shot, possible needs the linkage adjusting up for starters. I intend to do mine..........in the summer.
Mk2 GTi.
dubslug
04 January 2008, 16:48 »
think its the shorter of the two rods with plastic ends that controls 5yh, worth a look??
1992 pearl grey 8v
martinb
Forum Supporter
04 January 2008, 16:57 »
cheers for all your help, will pass on your advice to him
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #6 on:
04 January 2008, 17:12 »
yep short link rod prob has a crack, had this on my driver and had to push the stick down to get 5th. Was a small hairline crack too, impossible to see untill I took the linkage off and checked!
martinb
Forum Supporter
Reply #7 on:
08 February 2008, 21:04 »
right, well this car is now mine (well
technically
my other halfs) so will hopefully investigate this weekend
paultownsend
Reply #8 on:
08 February 2008, 22:29 »
on the 020 box if the oil gets low the 5th gear is the first to dry up, making engaging difficult
Ade244
Reply #9 on:
09 February 2008, 21:08 »
I was just going to post this question myself. My valver just started doing this today. Mine won't go into 5th when the cars hot, when its cold its OK. Probably the oil level low? I just had the clutch done so it could be a linkage also.
I'll check linkage and oil in the morning cheers
Ade
Golf mk2
