Author Topic: What is this remap  (Read 1202 times)
Offline Fatandre
What is this remap
« on: 03 January 2008, 17:32 »
Hi you guys. I have beend reading posts and you are talking about remapping. What is that?
Offline Hurdy
Re: What is this remap
« Reply #1 on: 03 January 2008, 19:25 »
Remapping is a method of changing the characteristics of the engine by electronically reprogramming the engines "brain" to make it more efficient and give extra power and torque.
An engine has several parameters that are controlled by this "brain" (or ECU as it is known) and these can be altered from the conservative original settings (that VW use) to higher settings. For example the fueling ratio's can be altered to give a more powerful combustion in the piston chamber. Similarly with turbo powered cars, the pressure in the system can be increased to give a higher combustion pressure and as a result more power. All in all tuners can alter in excess of 30 individual settings to free up more power in the engine. The better tuners tend to do more research and alter more parameters for a better balanced "map" and other tuners simply opt for upping the pressure and fuel mix.
Seat Leon Cupra Black 290 DSG
Offline Fatandre
« Reply #2 on: 03 January 2008, 19:50 »
How can I get this remap done and what do you recomend?
Offline Manu_R32
« Reply #3 on: 03 January 2008, 20:05 »
Search button  :evil:
OSIR Front Splitter - OSIR Rear Diffuser - RNS 510 - JL Audio Cleansweep - JL Audio 400/4 Amplifier - JL Audio ZR650 - Recaro Bucket Seats - 3.2 V6 of Pure Power!
Offline Hurdy
« Reply #4 on: 03 January 2008, 20:11 »
It would depend on whether or not you have any local dealers in Iceland who can remap your car for you. If not you could opt for the Superchips Bluefin remap. See the link Below
http://www.superchips.co.uk/superchips.php
