Author Topic: widetrack using mk3 bits  (Read 2576 times)
Offline juleshs
Re: widetrack using mk3 bits
« Reply #10 on: 04 January 2008, 17:59 »
mk3 arms will fit your rack, i have a mk3 rack with mk2 arms
VeeDubGTI16v
« Reply #11 on: 04 January 2008, 18:47 »
yeah i know dude, i need to know if the passat arms are the same length as the mk3 arms
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #12 on: 09 May 2008, 10:27 »
Im jsut browsing wdietrqack stuff.. not sure if youve proted voer your setup, and still need to know the lengths? i could probably tell you tomorrow, if weve got both passat and mk3 rods in stock  :smiley:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #13 on: 09 May 2008, 11:15 »
Bit off topic but which is the easiest way to do the back? rallye swap?
Offline Mew
« Reply #14 on: 09 May 2008, 11:24 »
The rallye rear end is nothing like a fwd mk2, the body is different and the suspension is independant rather than a beam.
Mark made a post about using a spacer on the rear stub axle i think, wait for him to answer!  :wink:
VeeDubGTI16v
« Reply #15 on: 09 May 2008, 14:29 »
i forked out for some new passat ones on the end! it would be useful to know though if you can be arsed
i put spacers behind the stub axles but i think some mk3 beams are wider so you could use one of them?
« Reply #16 on: 10 May 2008, 22:37 »
get stub axles from drums..
get them machined flat, slightly below the surface.. to completely flat them..
excort cossies, forget whih, have longer bolts, 10.9 tensile strength.. put them behind, stub on front bolts through, badabing..
saw it on cgti  :cool:
Quote
