Author Topic: Front speaker wiring  (Read 2182 times)
Offline DRobbo
« on: 01 January 2008, 17:43 »
I can't quite reach the wires to the front speakers (on top of the dash)... Any way to get easier access? Remove the air vent in front of it? (If so, how!?!?)
Cheers  :smiley:
Offline Jay
  • balding fat cvnt
Re: Front speaker wiring
« Reply #1 on: 01 January 2008, 19:21 »
Just a silly question, but have you removed the dash?
Offline DRobbo
« Reply #2 on: 01 January 2008, 21:23 »
Nope!
A wire broke off one of my speakers, and I can hardly reach it through the top of the dash... Getting a new windscreen soon, so might be easier to do it with no screen, but preferably like to do it before!
Offline JC
  • Back in the North.
« Reply #3 on: 01 January 2008, 21:26 »
sounds like is a  dash surround out job
not that had work since the stereo is out already
just a load of screws and the heater controls and the switches to unplug
30 minutes max to remove- extend the wires ( they are tight as it is, i just had to redo mine )  and refit it all back in  :wink:
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #4 on: 01 January 2008, 23:31 »
Remove the small cover the shape of a slanted square and remove the screw behind it. Then take off the speaker cover. Then you need a really really short screw driver to undo the screws holding the speaker in place. Carefully lift the speaker and the cables should come with it. :wink:
Offline DRobbo
« Reply #5 on: 02 January 2008, 12:14 »
Done!
Thats bits the easy bit  :wink: .... Its just the wires are so short I cant reach the one that has disconnected itself from the speaker!
Any other ideas anyone??
Offline BaxGTI
« Reply #6 on: 02 January 2008, 14:03 »
Rent a small albanian child to go down there and fetch it for you...
Offline Goops
  • mk2 gti 16v
« Reply #7 on: 02 January 2008, 14:37 »
 :grin:
Offline DRobbo
« Reply #8 on: 02 January 2008, 15:02 »
Lol!!!
Took the bottom of the dash of in the end... Then pulled the wiring down, fitted an extension... resoldered the speaker... And it still doesn't work properly!!!!
Ah well thanks anyway  :wink:
Offline mattkh
« Reply #9 on: 03 January 2008, 00:17 »
Hi
Swap the wires over.
