Author Topic: Door Pin Replacement  (Read 636 times)
Offline Teamheath
  • Mk2 Black Jetta
« on: 01 January 2008, 10:12 »
My drivers door on the Jetta drops loads on opening.  Has done since i acquired it, but yesterday i found a new set or genuine vw pins in the back of the glovebox.
I'm gonna have a go at replacing them if its easy enough to do.
Any advie or hints??  Or does it need to go to VW for this??
Thanks
Track Day Weapon - Mk2 Jetta GL??  Soon to be modded.....
Offline herbster
Re: Door Pin Replacement
« Reply #1 on: 01 January 2008, 11:13 »
Just make sure none of your hinge bolts are loose, otherwise good luck, you normally need a special tool to ensure a parallel pull as they are worn with a step and this locks up, take the door off from the door pillar and work just the door on a nice supportive area, if you try in situe you might wack the door due having to hit harder due to the suspension taking the blow out of the work!!!  :rolleyes:
FAB is my life and the CABRIO's the wifes!!!!
Offline Teamheath
  • Mk2 Black Jetta
« Reply #2 on: 01 January 2008, 13:44 »
Thats cool, i just remember a mate of mine having some trouble with one of his a while back.
Will give it a go when i'm down the garage working on it tommorrow.
