Author Topic: Plastic Side Trim Comming off  (Read 758 times)
Offline Goops
  • mk2 gti 16v
« on: 29 December 2007, 18:24 »
Hi Guys,
I was giving the car a good wash today. Anyway..
I was waxing the side door and noticed that the plastic side trim on the driver side door (the smallest plastic trim near the door hinge, nearest to side indicator) was quite loose. It was almost coming off so i had a closer look. It was not held by anything, seems to have some remains of a black resin, there is small a rivet hole but i do not see how this would clip?? :undecided:
If anyone could shed some light that would be great.
I have bought some 6mm adhesive spacer pads, double sided adhesive tape for fixing number plates and was wondering if this would suffice?? :huh:
Thanks in advace  :smiley:
G
Offline golf mk2 tornado red
  • same s**t just another day
Re: Plastic Side Trim Comming off
« Reply #1 on: 29 December 2007, 18:33 »
iirc should have a peg to locate it .is this bit built into arches or dont u have them anyway double sided will do the job
Offline Goops
  • mk2 gti 16v
« Reply #2 on: 29 December 2007, 19:22 »
Hi,
Did not see a peg on the underside of the trim?
I will check if the rivet hole has anything broken inside it,  :undecided: otherwise the double sided adhesive wil have to do!
Thanks,
G
Offline BaxGTI
« Reply #3 on: 29 December 2007, 21:08 »
If yours is the thin trim like mine then it has white pegs all along it...if it's the thicker stuff, not sure.
Infact, on the right hand side of the shorter trim you can just see the white peg in this pic:
Offline dubslug
« Reply #4 on: 29 December 2007, 22:48 »
there wll be a white peg it slots into, if these snap they can push into body work hence it looking like its coming off
1992 pearl grey 8v
