Author Topic: Anyone with a KR, i need help!  (Read 573 times)
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« on: 29 December 2007, 17:54 »
as above, on the KR engine. On the ECU theres two plugs. In the top left plug theres a black wire that runs down the rain tray/ scuttle panel, then pops out through the wiring for the coil. Its quite long and relatively thin, it enters the bay near to the coil.
Where does it go? Mines just hanging loose and since i guess its an earth for the ECU i think it may well be the reason im getting no spark from the king lead and hence not firing.
Thanks.
Offline Idle Duffer
Re: Anyone with a KR, i need help!
« Reply #1 on: 29 December 2007, 23:12 »
It plugs into the coil on the supply side.  Black on Mk2 is generally Ignition switched power. Plug it in and it should fire up just fine.
