Author Topic: Noisy Heater fan..  (Read 3249 times)
Offline grantmak
Noisy Heater fan..
« on: 29 December 2007, 00:50 »
Hi folks,
Anyone had this very annoying problem of a noisy heater fan on my MK2, it sounds like it might be rubbing or something!!
The noise level varies, sometimes very loud squeeking and rubbing sometimes not so.
Is there an easy cure!!!  :sad:
Oh and Merry Christmas by the way  :smiley:
Grant..
Offline Neaty
Re: Noisy Heater fan..
« Reply #1 on: 29 December 2007, 01:37 »
wear a coat  :grin:
Offline cняis
« Reply #2 on: 29 December 2007, 01:51 »
the blower bushes have probably dried up, get the blower out and lube the bugger!
to get the blower out:
passenger footwell, remove the foam/carpet covering, unplug the blower wires (blower is located near to the door), the blower assembly just twists to undo, be careful not to snap the plastic lugs...
then get the WD40 on it...
Offline grantmak
« Reply #3 on: 29 December 2007, 05:13 »
Cheers for that Crevice,
Will do that when i get home..working offshore jist now so next wednesday will do the buisness..
Offline JamesS
« Reply #4 on: 29 December 2007, 11:47 »
I have had the same problem for a year on my heater fan but that noise is only there on speeds 1&2 so I just turn it up to 3! I think it's time to sort it out, ive just beeen lazy.
jim
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
Offline Conker
« Reply #5 on: 29 December 2007, 15:28 »
You can also get to the fan through the engine bay. Take off the plastic trim below the windscreen (scuttle tray??) and you will see the air hole into the cabin. You can reach a WD40 can down into the hole and spray the fan through holes in the fan blades. This cured my fan noises, but only lasts a few months.
Makes the cabin stink too!
Offline Dec
« Reply #6 on: 29 December 2007, 15:31 »
jim
mine only works on 3 and squeeks like a b!tch! What would the problem be as it doesnt seem to do anything on 1&2 :sad:
Offline dubslug
« Reply #7 on: 29 December 2007, 15:36 »
sounds like the resistor has gone......
1992 pearl grey 8v
Offline Dec
« Reply #8 on: 29 December 2007, 15:36 »
Is it easy to change that if it can be changed or is it a new motor job :sad:
Offline dubslug
« Reply #9 on: 29 December 2007, 15:37 »
i just changed whole unit but then i knew i had one in shed that worked
1992 pearl grey 8v
