Author Topic: handbrake problems  (Read 801 times)
Offline BIG D
handbrake problems
« on: 23 December 2007, 13:29 »
Hi ive just put disc's and pad's on the rear of my gti the foot brake is fine but when you pull the handbrake the caliper looks like its working but it's not gripping the disc can anyone help because i can only think that the calipers need replacing
Offline pork_pie
Re: handbrake problems
« Reply #1 on: 23 December 2007, 13:37 »
you need to action the handbrake a good 50 -80 times, and the calliper will ratchet itself out.  I had the same problem with mine; the Haynes book doesn’t mention it at all.  I only found out when I quizzed my old man, he said there was a note in the box that came with his new callipers highlighting the problem.  hope it helps
Mk2 16v is off the road :(  Mk3 8v has taken its place :)
