Golf mk2
diesel starter motor
Topic: diesel starter motor (Read 1266 times)
dubslug
22 December 2007, 11:03 »
hi all having screwed up my 2l conversion and taking it to a garage, they have said i could use a diesel starter as it will have more cranking power, is this true and if so which engine code starter do i need??/
cheers
rik
1992 pearl grey 8v
dubslug
Re: diesel starter motor
25 December 2007, 17:26 »
no one got any ideas??
need more cranking power on my 2l bottom end
1992 pearl grey 8v
DogDay
GTI forum regular
26 December 2007, 10:41 »
Well...
These codes are all from mk3 diesels
My N/A Diesel is
1Y
My TD Diesel is
AAZ
These are both the older IDI (indirect injection) engines - they have higher compression than the newer TDi engines - 22.5:1 vs 19.5:1.
The newer TDi engine codes are:
1Z
AHU
ALE
AFN
AVG
- The 1.9 N/A SDi is
AEY
For more info do a search in
http://vwdiesel.net/phpBB/
DD
Shame you're not any closer - you could have had my spare
Bow Chikka Wow Wow
Gernster
26 December 2007, 12:17 »
ive got the 1.6 IDI Turbo diesel (mk2 GTD) and the engine codes for those are RA or SB. Cant help you with compatibility though mate.
Gernster - GTi-TD
dubslug
26 December 2007, 20:46 »
many thanks guys, i believe any mk 2 will fit...
well i hope anyway
1992 pearl grey 8v
jase555
Here all the time
DUBS DONT DIE, THEY JUST GET LOWER!!
28 December 2007, 16:02 »
wont you need a deisel battery as well because the starter takes more juice? also putting a deisel battery on your standard battery will give it more torque.
Golf mk2
