Author Topic: Strange bolt head  (Read 1309 times)
Offline dadrathers
Strange bolt head
« on: 21 December 2007, 20:23 »
I might need to replace the crankshaft pulley(s) and have found a few threads on the subject - all very helpful. They suggest that to remove the pulley bolts you can stop it rotating by using a spanner on the crankshaft sprocket bolt. However, mine isn't a normal hex head bolt - it is sort of fluted. It looks like it has been cut out using a pastry cutter. Do I need a special VW tool then to grab this head??
Any help appreciated and Merry Christmas!
Offline golf8v
Re: Strange bolt head
« Reply #1 on: 21 December 2007, 21:39 »
its just normal socket (not a six sided one)
Offline nealey
« Reply #2 on: 21 December 2007, 21:41 »
19mm 12 sided socket iirc
Easy to get hold of one
Offline dadrathers
« Reply #3 on: 21 December 2007, 23:10 »
Yeah, it's not got 12 sides. I can't think of any better way to describe than as if it has been cut out by a pastry cutter - you must have had a mince pie this Christmas - it looks like the edge of the top of the mince pie??????
Leon R
« Reply #4 on: 22 December 2007, 14:12 »
Thats called a multi-hex, and i'm quite sure as Nealey said, its a 19mm 12 point. Take a picture for us?
Offline dadrathers
« Reply #5 on: 22 December 2007, 19:09 »
Thanks guys - I will take a closer look and count the sides!!! Hopefully it has 12 so that I can get the appropriate spanner. Do Halfords do them? I quite like their 'Professional' tools - good quality at reasonable prices.
Offline ...joe
« Reply #6 on: 22 December 2007, 19:12 »
^^ i have a set of halfords professional tools and i use the 19mm socket to turn the crank.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline dadrathers
« Reply #7 on: 23 December 2007, 16:48 »
Apologies chaps - of course a 19 mm socket, as you say, fits a treat.
The head does look like the top of a mince pie though!!!!
