Author Topic: What be wrong with my car lol!?  (Read 1094 times)
Offline BSCR
« on: 21 December 2007, 13:47 »
Golf Driver, 1.6 J plate Aug 1991 8v engine code EZ.... (Hope thats enuf info, shout if not)
Well if any of you have stumbled across my project thread u will already know that it had a water leak.
Today i set about fixing it, iv replaced the O ring that i thought was causing the leak and also the sensors that look a lil rusty to say the least. I took it out for a quick blast got back and there is steam coming out of the engine, the leak appears to be worse now?! might put the old parts back on !!!!
My main issue is that when running the car with the water filler cap off a foamy white substance comes to the top? Why is this? is it something to worry about? I checked for the obvious signs of a blown head, lack of power (not enough experience to say) white exhaust smoke (its damn cold but i think its just the temperature difference, steam?) White exhaust tip - deff not its black.......another thing i must look at. Mayonnaise in the rocker cover cap? None to be seen.....
So im at a loss? Anyhelp or advice / things to check?
Cheers in advance
Offline Organisys
  • Old and Slow...
Re: What be wrong with my car lol!?
« Reply #1 on: 21 December 2007, 13:50 »
Flush out all the old coolant, replace it and see if any comes back. If it does, get a compression check done.
Offline BSCR
« Reply #2 on: 21 December 2007, 13:52 »
Cheers, Sorry to be dunce but how do i flush it out? and what should i replace it with?
Offline Dec
« Reply #3 on: 21 December 2007, 13:57 »
I just took one of the hoses off the cable and put new coolant in.
When i say 'I' i mean my dad :grin:
I think theres a thread in the maintanence section that ill find for ya :smiley:
This this is the one: http://www.golfgtiforum.co.uk/index.php?topic=33252.0
Offline Organisys
  • Old and Slow...
« Reply #4 on: 21 December 2007, 14:02 »
Hose pipe or lots of fresh water. Then replace with more water+anti freeze.
Offline Diamond Hell
  • Opinions я Us
« Reply #5 on: 21 December 2007, 14:07 »
Get a garage (or friendly AA Man) to do a sniffer test on it - you may have a crack in the head which is releasing carbon monoxide into the coolant.
Does the car idle OK?
Offline BSCR
« Reply #6 on: 21 December 2007, 14:43 »
It runs brilliantly, (apart from the what appears to be very common, high revs on start up) :smiley:
Iv think iv found the leak issue, cracked plastic bit i think, so ill replace that. It was fine yesterday but i guess taking it on and off has fooked it. VW said it was a tenner ish
And when thats done ill try and replace all the coolant, Cheers Dec For the link, and to Organisys for the info and to Diamond Hell for the advice on the "sniffer test" last call there i think :smiley:
Merry Christmas
