Author Topic: Shed-esque Golf2 Syncro  (Read 420451 times)
VeeDubGTI16v
Re: Getting not-so-cheap-assed Golf2 Syncro track toy.
« Reply #200 on: 01 September 2009, 19:25 »
still softer than poly though  :wink:
Offline Diamond Hell
  • Opinions я Us
« Reply #201 on: 01 September 2009, 20:46 »
cos its rubber duh
No, that's utter balls.
Have you had hold of these little suckers?  Compared them side by side vs the polybushes?
What's the compound?  'Rubber' ain't rubber these days.  It's a compound.  The hardness of the compound is controlled massively by the formulation and density.  These are OEM spec parts from a 'sports car' or an ultra-high performance hatch.
If the TT bushes were designed to fit the TT and the S3 they've been designed to be worked exceedingly hard.  I suspect the 'design' in a lot of polybushes is 'how can we make it not too hard to fit in?'  They figure a shape out, then take the poly material out of the freezer and machine it down appropriately, before shoving it in the hole and seeing how it works. If it's not quite right then they probably have another few goes.
I rather suspect there's a *touch* more R&D in the TT bushes I've just pressed into my control arms than the R&D that went into the polybushes.
Consider how the bushes are constructed?  Metal outer (so less bushing material).  This is then bonded to the bushing material, which is then bonded to the inner shaft.  The whole thing's tighter than a nun's chuff.  Compare this to the poly unit, which has no outer metal surface to bond the bushing material to and then has a metal insert that can be just pushed in by hand.
Believe me they were a LOT stiffer than I remember the polybushes being when they went in.  I don't think £27 for the pair of them was all spent on scene whoreage points.
VeeDubGTI16v
« Reply #202 on: 01 September 2009, 20:47 »
well as long as your happy
  • Opinions я Us
« Reply #203 on: 01 September 2009, 21:28 »
I'll bet you can't actually ever remember being wrong, can you?
Not even when it comes to grammar and spelling.
Offline JC
  • Back in the North.
« Reply #204 on: 01 September 2009, 21:30 »
as and when you need the ballast test carrying out Tom give me a shout  :grin: :wink:
  • Opinions я Us
« Reply #205 on: 01 September 2009, 21:48 »
The words 'Brands' and 'December' spring to mind for some reason.  :wink:
Offline Horney
« Reply #206 on: 01 September 2009, 21:52 »
Oh rely? I was thinking I was done for the year with mine due to needing a lot of new tyres but I reckon December I can have it all sorted!
Nick
VeeDubGTI16v
« Reply #207 on: 02 September 2009, 09:25 »
 :grin:  :wink:
Offline Horney
« Reply #208 on: 02 September 2009, 09:27 »
It's like an unmovable object meeting an unstopable force!
Nick
VeeDubGTI16v
« Reply #209 on: 02 September 2009, 09:35 »
the unmovable syncro v's the unstoppable valver  :laugh:
