Author Topic: Small Things....  (Read 2892 times)
Offline jim182
Small Things....
« on: 17 December 2007, 09:50 »
Right i picked my new golf up yesterday from bradford... 3 hour drive but it was worth while! shes a g reg 1600 with full 90 spec gti trim inside n out in red.. nice looking respray 6months ago... bbs RA's... jetta front end :sick:(imo)...Gti suspension... scorpion zust(i think)...German style plates... basically shes a very clean looking car!!
Just a few things that need sorting
i need some advice on...
Dash lights dont work! .... (is this easy to fix? i was thinking of gettin blue ones off ebay)
speedo is wrong and makes a clicking sound!... (what could be causing this?)
Heating only works on speed 3 and stays cold... ( how do i fix this?)
Things i wanna do
Get rid of jetta front end :smiley:
Wire front fogs up
change zust for a nicer looking and sounding one
clear indiys n side repters
il get some pics up 2mo :smiley:
jim
www.myspace.com/deadcannons
Previouse Dubs - Mk2 1.3, Mk3 1.4 SE, Mk2 1.6 Gti Replica - Currant boring company Audi A3 & Type 19 1.6 Driver
Offline Dolly
Re: Small Things....
« Reply #1 on: 17 December 2007, 10:03 »
heater your probably looking at ditching the bypass valves, and probably a new matrix if yours is all gunked up. and maybe a new fan unit if it doesnt blow on 1 or 2?
Offline jim182
« Reply #2 on: 17 December 2007, 10:05 »
Ahh cheers man!
you kno if thats gonna be expensiv??
nope dont get any blow till its on 3 and then it sounds rough!
Offline jammac
« Reply #3 on: 17 December 2007, 10:13 »
its always worth flushing the coolant system first cos the heater matrix is quite time consuming and highly annoying! (but OHHHHHHHHH so satisfying) chances are the system could do witha flush anyway.
a quick way to tell if ya matrix is fubard is to remove both hoses going through your engone bay bulkhead into the cabin and run a hose into the heater matrix if the flow is restricted your heater matrix is blocked.
if i were you though id flush the system and then bleed it properly as per rubjonnys guide in the mk2 maintenace and info as an airlock in the matrix will stop the heat aswell.
heater matrix new costs £36 from GSF. if you get it done at a garage it would probably cost a bomb as like i said its quite time consuming and you know the garage arent gonna rush to get it done. its not hard to do its just abit fiddley! but once i had done it i was amazed at how hot the heater is and i never thought having a heated car would be a novelty!
dash lights.......sounds like a fuse as the whole dash isnt working
dunno about the speedo mate
ITS A TRAP!
Offline JC
  • Back in the North.
« Reply #4 on: 17 December 2007, 10:29 »
welcome to the world of " Small Things "   :grin: its just when you start fixing them that you find the  " Big Things "   :cry:
VeeDubGTI16v
« Reply #5 on: 17 December 2007, 10:31 »
souds like there is 2 problems with the heater, change the relay on the motor to get all speeds working, and replace the bypass valve to get heat again/ or you have an airlock.
 i didnt think the matrix's stopped working, thought they just leaked!  dont know about the other problems
Offline jammac
« Reply #6 on: 17 December 2007, 10:38 »
my heater stopped working as the matrix was only letting a dribble of coolant through
ITS A TRAP!
Offline jim182
« Reply #7 on: 17 December 2007, 10:48 »
It all sounds confusing!
I fink il get one of my mates who unlike me knows somthing about cars to have a look at it!!
also it came with a toad alarm & immo and on the remote it has two buttons but only one is used!
would it be possible to fit central locking and then tune it to the right frequency so this other button would lock and unlock the car insted of having two fobs on my keys??
Offline Dec
« Reply #8 on: 17 December 2007, 10:51 »
My heater squeeks on 3 and only blows air out on that setting aswell :sad: i just leave it on 1 and it lets warm air through lol is it hard to change the motor? it sounds like its near the glove box when it squeaks.
Offline MK2RussRacer
  • Entscheidendes Volkswagen abstimmen!!!
« Reply #9 on: 17 December 2007, 11:02 »
Dont wanna teach u to suck eggs but u know about the dash illumination button dont u?
i thought mine didnt work till i found that and it was wound right off  :rolleyes:
PIMP TRACK 20V GROWING HERE >>> http://www.golfgtiforum.co.uk/index.php?topic=72748.msg586287#new
Translate this and tell me the film it comes from for a prize!!!
Es doesnt Materie wether, die Sie durch einen Zoll oder eine Meile gewinnen,. Gewinne gewinnend.
