Author Topic: Strange electrical fault! Please help!  (Read 1218 times)
Offline VW_valver
« on: 15 December 2007, 19:56 »
Hey everyone, well I've encountered a strange problem after replacing my 1.8 16v engine with another one. Everythings bolted in properly and all wires connected up but heres my problem:
If I turn the key to the first click of the ignition only the oil light comes on and the dash clock, then if I turn the key to start it the oil light and clock go out and the dash lights come on!  :huh: but the engine doesnt turn over and neither does the fuel pump prime.
Anyone got any solutions as Im at my wits end now.
Cheers,
Andy
Offline mattkh
Re: Strange electrical fault! Please help!
« Reply #1 on: 15 December 2007, 20:05 »
Anyone got any solutions as Im at my wits end now.Cheers,Andy
Hi
What was the ignition switch like when you had the old engine in the car ?
Offline hexomire
  • G60 powered
« Reply #2 on: 16 December 2007, 01:00 »
check the grounding.
Offline VW_valver
« Reply #3 on: 16 December 2007, 20:16 »
The ignition worked as normal before I changed the engine, not sure whats wrong.
As far as earthing goes Im sure everythings connected properley.
Will it make any difference that the new engine is from a corrado?
Cheers,
Andy
Offline VW_valver
« Reply #4 on: 17 December 2007, 14:39 »
BUMP  :sad:
Offline VW_valver
« Reply #5 on: 20 December 2007, 17:49 »
Now sorted, it was a combination of corrosion on the earth lead that goes to the gearbox and also where the earth lead contacts the car by the battery.  :grin:
Cheers,
Andy
