Author Topic: Rust Protection?  (Read 3037 times)
Offline Conker
Rust Protection?
« on: 15 December 2007, 14:33 »
After temporarily removing the upper torsion bar from my Mk2 (better access to the head), I've found light rust:
What should I do to protect the turret before I screw the torsion bar back on again - Is there some sort of grease I should apply e.g. copper grease?  The bolts for the torsion beam do not have nuts, they are just screwed straight into the body shell, so should I also be protecting the bolt holes as well?
Cheers for any suggestions.
Offline hobbiniho
Re: Rust Protection?
« Reply #1 on: 15 December 2007, 17:06 »
clean rust back to bare metal and spray with etch primer then paint whatever colour you want and for the holes i would put plenty of copper grease on them, last thing you want is your suspension turrets rusting away  :cool:
Offline Uruk Hai
« Reply #2 on: 16 December 2007, 17:47 »
As above I would strip the area back to the bare metal and sand/grind any rust left then I would use a good rust treament on the whole area and then etch prime  :wink:
Offline Conker
« Reply #3 on: 16 December 2007, 19:51 »
Balls.
I was hoping to just spray on some sort of uber-grease to prevent all further oxidisation.
 :sad:
Offline hobbiniho
« Reply #4 on: 16 December 2007, 19:52 »
clean it up while it is still only a minor problem, you will thank yourself later  :cool:
Offline Conker
« Reply #5 on: 16 December 2007, 19:54 »
Can't believe the 'tard that fitted the torsion bar didn't do more to protect against damp that would obviously build up underneath it. Grrr.
Offline dadrathers
« Reply #6 on: 18 January 2008, 22:17 »
Probably a bit late now - I guess you have put the torsion bra (deliberate) back on. But i would blather the whole thing in Waxoyl - unless you want the paintwork to be as good as the exterior bodywork - lol
I swear by Waxoyl - amazing stuff.
Offline Conker
« Reply #7 on: 19 January 2008, 00:30 »
I've not refitted it yet as I've been doing loads of work on the engine and it gets in the way.
I was wondering if I could use waxoyl...
Offline Uruk Hai
« Reply #8 on: 19 January 2008, 08:03 »
IMO waxiol is very good but I would still sand/grind all the rust you can see then use a good rust treatment and then plaster with waxoil. Just make sure your realy thourough, you dont want that area rusting out  :shocked:
Dinky
« Reply #9 on: 19 January 2008, 11:05 »
^ftw! :cool: will be worth it in the long run..tis the treatment the cab is getting..but im also hammeriting every inside panel..seemed a good idea at the time :laugh:
Dinx :kiss:
