Author Topic: Back light not working on heater controls?  (Read 2331 times)
Offline terri8le1
« on: 14 December 2007, 10:22 »
hi chaps, small problem, when i turn the headlights on the heater controls dont light up, so i ant see which one i'm turnin in the dark, anyone know why? could it be a fuse or somethin? Also, the cigarette lighter doesnt work, whether they are linked, i dont know. Any help apprieciated, cheers.
Offline northernlad
  • Ta biatche
Re: Back light not working on heater controls?
« Reply #1 on: 14 December 2007, 10:24 »
Yeah it will be fuse mate, also could be a blown bulb which caused the fuse to blow.. check your fuses and check bulbs on controls..
*** VAGSLAGS -> -> WWW.VAGSLAGS.COM
Offline terri8le1
« Reply #2 on: 14 December 2007, 10:30 »
Cool, thought so, bit of beginner so where is the fuse box again? Cheers!
Offline krave
« Reply #3 on: 14 December 2007, 10:50 »
underneath the dash, drivers side by the door!  :smiley:
Offline terri8le1
« Reply #4 on: 14 December 2007, 10:54 »
cheers fella, gonna go sort it now. One quick question, when changing a headlight bulb, does the whole light have to come off or does the plastic lense clip off or.....?
Offline Mikester
  • Civic Type R
« Reply #5 on: 14 December 2007, 11:42 »
The back comes of, not the front.
Offline bored_Welsh_lad
« Reply #6 on: 14 December 2007, 14:01 »
the bulb is a single bulb and a piece of piss to get to ill see if i can find the guide on the tex' for it...
awesome!!!
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline terri8le1
« Reply #7 on: 14 December 2007, 15:53 »
Cheers chaps, sorted the back light on the heater controls out, turned out to be a blown bulb, 50p later its sorted. Just gotta sort me headlamp out now and the power steerin belt slippage.
« Reply #8 on: 14 December 2007, 18:15 »
does the belt slip more in the wet than the dry and give you this horrible... im not going to turn for you symptom??
Bumper Vents :D
Offline terri8le1
« Reply #9 on: 15 December 2007, 03:09 »
yeh thats it, i started a thread about it b4, people described the exact symptoms, so i'm pretty sure its the belt, dontthink i can change it meself tho, cant find the belt for a start plus aint got the right tools i'm guessin?
