Author Topic: Retrofit heated wing mirrors  (Read 4745 times)
Offline orca
« on: 13 December 2007, 19:25 »
Is it possible to retrofit heated wing mirrors?  My old 2004 2.0 GT TDI had them as standard and I didn't realise that the GTI didn't have them as standard :(
It was a pain going to work this morning.  I had to scrape the mirrors, and then they started to freeze on the journey at various points, when I hit some cold pockets.  It got down to -3.5C in some areas.
Offline Pintman
Re: Retrofit heated wing mirrors
« Reply #1 on: 13 December 2007, 20:52 »
I thought they did.  Check the spec.
http://www.volkswagen.co.uk/new_cars/golf/standard_spec
Don't know the location of the heated wing mirror button on your GT TDI, but the GTi has it on the same knob as the wing mirror adjustment on the door.  Just rotate it around 180 degrees.  If that doesn't work, firstly check the fuse.  Other than that, looks like a trip to the stealer to get fixed.   :wink:
Offline orca
« Reply #2 on: 14 December 2007, 00:36 »
My GTI is an import from Holland.  Could be that the option is not standard there ?  I've got the low washer fluid warning though (not got the winter pack option).  Can't be too difficult to get heated mirrors fitted can it?
Offline Rhyso
« Reply #3 on: 14 December 2007, 12:46 »
all depends on how difficult the wiring is; you'd need to run a loom to each mirror and also to the switch; not sure if it needs to go through the CCM though.  Parts wise it could be a bit pricey; best bet is to rob bits off a crashed Golf with them
Offline maxamus
« Reply #4 on: 14 December 2007, 13:33 »
wow i never knew they had heated wing mirrors as default. I didnt know that. Mine has it on the controls but its kind of hidden and i didnt know it was there
Offline indublin
  • "Hotel California" forum.... you can log off anyti
« Reply #5 on: 14 December 2007, 17:38 »
Well "all gu't t't fut't of arr sters" 180 degrees on the switch = ??? degrees on the wing mirrors. You learn somthing new every day!
P.S. The wife and a few close friends think I am a Golf Gti Geek spending so much time on this site!
Steel Grey 2006 GTi 3-Door - Monza II's - Tinted Rear Windows - Arm Rest
Offline orca
« Reply #6 on: 14 December 2007, 19:55 »
Hey Pintman, thanks for the tip.  Sorted now!  I was a complete muppet.  I'll blame VW anyway for changing the design, although it is a better design.
The wing mirror control knob on the GT TDI had 3 positions - L-Heater-R.  The GTI has 4 positions - L-Off-R and Heater at 180 degrees.  I couldn't see the heater position from my driving position so assumed that it only had L-Off-R.
Cheers.
Offline illyun
« Reply #7 on: 14 December 2007, 20:00 »
You've never used Climate Control and now this... have you actually driven your car?   :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin: :grin:
Mk1 GTI Campaign, Mk5 GTI Edition 30, Mk6 GTI (Coming Soon...)
Offline maxamus
« Reply #8 on: 14 December 2007, 23:28 »
I've never used AUTO on climate control and i couldnt see the heated mirror signal from the driving position.  :smiley:
You learn something new every day
Offline Manu_R32
« Reply #9 on: 16 December 2007, 13:26 »
What are the functions of Auto on climate control...?? I never seem to get it
OSIR Front Splitter - OSIR Rear Diffuser - RNS 510 - JL Audio Cleansweep - JL Audio 400/4 Amplifier - JL Audio ZR650 - Recaro Bucket Seats - 3.2 V6 of Pure Power!
